[mapguide-users] MGOS2.0.2 bundled installation won't support php on IIS6
Rock Beans rockbeans at gmail.com
Thu Sep 25 11:12:03 EDT 2008
This is a loaded question. MapAgent and MapAdmin are completely
separate. In Windows environmental variables make sure the PHP path is
first for the variable named PATH. Also, create a txt file name it
phpinfo.php, add the phpinfo code and run from browser. Place this
file in your mapguide www folder so it is web shared. If it runs then
you know PHP is working. Note the config INI path and make sure it is
using the INI from the mapguide os php folder.
In IIS isapi_MapAgent.dll is for .fcgi files make sure you allow this
extension in IIS or allow all for ease of development.
In IIS php5isapi.dll is for .php files make sure you allow this
extension in IIS or allow all for ease of development. Some times
using the php-cgi.exe can fix problems but is more resource intense.
Code for phpinfo.php Page:
<?php
     phpinfo();
If you want to skip all this just install bundled with Apache on some
other port like 8008 and move on.
Regards,
The Rock
On Thu, Sep 25, 2008 at 9:14 AM, brianlee <pengxianghepipi at 163.com> wrote:
> Hello,
> I installed the MGOS2.0.2 by IIS bundled intallation, php & Asp.net as well
> as Java.
> but I did not get the php running on IIS.
> I have make sure the web service extension is set as isapi_MapAgent.dll.
> Verifying the installation by
> http://servername/mapguide/mapagent/mapagent.fcgi?operation=enumerateresources&version=1.0.0&locale=en&resourceid=library://&type=&depth=-1
> returns error.
> [Invalid repository type.
> Invalid repository type. Exception occurred in method
> MgResourceIdentifier.CheckType at line 716 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
> I can not access the admin page as well:
> http://servername/mapguide/mapadmin/login.php
> to load the sample data packages.
> I can open the site by Autodesk MapGuide Studio 2008, to see there is
> nothing in the site.
> Is there somebody who can help?
> thanks
> View this message in context: http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19670417.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
