[mapguide-users] buffer is not accurate
EvaD evadraganov at yahoo.com
Thu Sep 25 13:46:12 EDT 2008
When I do buffer 100 feet, the end result is smaller around 30.30 feet, and I
am using release 2.0 with .Net/ mapviewernet /.
I read in the ticket #226 that this issue is fixed since version 1.2, but
seems in my case is still persistent.
Is there a version that the problem with the buffer is solved, or any other
way to get around this problem?
Thank you!
View this message in context: http://www.nabble.com/buffer-is-not-accurate-tp19672598p19672598.html
