[mapguide-users] mapguide and fusion - a status report
Paul Spencer pagameba at gmail.com
Thu Sep 25 21:21:07 EDT 2008
I thought it was OpenLayers.i18n - looking at the code, it is in fact
both OpenLayers.Lang.translate OR OpenLayers.i18n, they point to the
same function.
As Jason said, you can drop in fusion 1.1 and use the existing
MapGuide templates with the above change.
Cheers
Paul
On 25-Sep-08, at 8:43 PM, Jason Birch wrote:
> Hi r0ss,
> My suggestion would be to wait for the Fusion 1.1 release, and then
> just replace the existing fusion directory.  Once that is in place,
> you'll have to patch the existing templates if you're using them:
> http://trac.osgeo.org/mapguide/ticket/676
> This requires a bit of skill with the patch command (uh, and you
> have to install it from Cygwin or GnuWin32 first).  If you have a
> decent text editor, you can alternately do a global search and
> replace in all of the index.html pages under fusion/templates,
> replacing:
> OpenLayers.String.translate(
> with
> OpenLayers.Lang.translate(
> You'll also likely want to look into the new Fusion single file
> build process, as it really improves initial load time.  I've
> written about this before:
> http://tinyurl.com/fusionsf
> The build system in trunk might be even better (combines CSS files
> as well), but I haven't had a chance to see if it works with the 1.1
> branch yet.
> Jason
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org on behalf of r0ss
> Subject: RE: [mapguide-users] mapguide and fusion - a status report
> This is a great note to provide clarification for those of us who
> missed
> some of the other threads.
> Quick question - does a document exist that outlines the changes
> that one
> would need to make to upgrade MGOS 2.0.2 to version 1.1 of fusion -
> you
> mention some minor changes need to be made?
> I assume I would spent an hour or so on Nabble trying to figure all
> of this
> out and a summary document would be greatly appreciated until all of
> this
> gets sorted out.
> <winmail.dat>_______________________________________________
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
