[mapguide-users] CS Map
Jason Birch Jason.Birch at nanaimo.ca
Sat Sep 27 00:36:33 EDT 2008
CS Map will be available in the next feature-release of MapGuide Open Source.  You could try running from SVN; the build process has some prerequisites and takes a while but is not all that painful, but running MapGuide from the build tree is a bit different (paths and stuff) than running from the installer.  Because this is essentially just a port of the CS code that was already running inside Enterprise, there shouldn't be too many teething pains.
As was mentioned earier, we're trying to get an open nightly build (and package) process put in place for MapGuide.  Trevor has been kind enough to offer some support for this, and hopefully we can make this happen for the 2.1 release.
Jason
From: mapguide-users-bounces at lists.osgeo.org on behalf of Rock Beans
Subject: [mapguide-users] CS Map
Did I just see the CS Map Mentor (Commercial Coordinate System) be
implemented within MapGuide? If so, when will it be ready for usage or
would I have to get SVN and compile myself?
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080926/2f508a12/attachment.bin
