[mapguide-users] MGOS2.0.2 bundled installation won't supportphp on IIS6
Ed Jobe ed57gmc-bus at yahoo.com
Sun Sep 28 16:44:59 EDT 2008
I manually added \php\5.2.5\IniFilePath. I did not att the sysvar since the
php website searchs the registry. I restarted IIS and tried to login again.
It still returns a 500 error.
I don't know what to do next.
Ed Jobe wrote:
> Thanks Jason
> I ran phpinfo and everything looked ok there, i.e. the ini file was
> correct. However, what I stated about the registry, I don't even have the
> "php" key, nothing. Also, I don't have an environment var called PHPRC.
> Of course I could manually add them, but I'm sure I would be missing some
> other key data. How do I fix that? Would compiling the dll be enough?
> Ed Jobe
> ----- Original Message ----
> From: Jason Birch <Jason.Birch at nanaimo.ca>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>;
> Sent: Friday, September 26, 2008 9:44:55 PM
> Subject: RE: [mapguide-users] MGOS2.0.2 bundled installation won't
> supportphp on IIS6
> Before you get into compiling the DLL, if you don't have that key you
> should add it as documented in the trac ticket.  Without this in place,
> PHP will not pick up its php.ini settings from the correct location, and
> the Mg API will not be available.  I've seen this happen in the past, I
> believe when doing a custom IIS install with ASP.Net as the default
> language, and also installing the PHP viewer.  In some configurations, the
> installer just seems to miss that key.  Fortunately, I haven't run into
> the unfixable problem that Crispin has encountered yet...
> The way to tell if PHP is installed properly is to create a file in your
> mapguide www directory called something.php including the tag <?php
> phpinfo(); ?>.  This will output your current settings, showing where PHP
> is reading its ini file from, and also indicating whether the PHP
> extension is installed.
> Jason
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org on behalf of Ed Jobe
> Subject: Re: [mapguide-users] MGOS2.0.2 bundled installation won't
> supportphp on IIS6
> I do not have a HKEY_LOCAL_MACHINE\SOFTWARE\PHP in my regsistry.
> Crispin @ 1Spatial wrote:
>> http://trac.osgeo.org/mapguide/ticket/454
> mapguide-users mailing list
View this message in context: http://www.nabble.com/MGOS2.0.2-bundled-installation-won%27t-support-php-on-IIS6-tp19670417p19715358.html
