[mapguide-users] .NET Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Mon Sep 29 10:52:23 EDT 2008
I did not port the php code, I did not have a reason too.  You are able
to access the Mapguide API with fusion in .NET just as you would via the
AJAX Viewer via the Task Pane.
Brian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of brianlee
Sent: Friday, September 26, 2008 9:50 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] .NET Fusion
How is the integration .Net with fusion going?
have you port the fusion\MapGuide\php into fusion\MapGuide\DotNet by C#
or
Vb.net?
what's your configuration of your mgos app?
please kindly provide some infomation about get fusion running on .net
platform.
thanks
Berdel, Brian wrote:
> You are correct about the widgets and .NET, I actually started
> converting them a while back, but I haven't been able to dedicate
enough
> time to it...
> And yes I am using the task pane, and the feature reader works fine
for
> accessing a layer by layer name and session variable, but if I try to
> open a map via the name it always tells me it cannot find...One other
> question I would have about fusion is how to access the mapframe from
> the task pane...
> parent.parent.mapframe does not exist.  I saw the documentation about
> building a fusion template, but I a haven't really been able to get a
> handle on the structure as it relates to the regular AJAX viewer.
> Thanks,
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
> Sent: Thursday, April 17, 2008 2:20 PM
> To: MapGuide Users Mail List
> As far as I know, Fusion works with a .Net install, but you can't
write
> widgets in .Net unless you re-write the entire widget stack in this
> language.  This is something that I'd be interested in seeing, but
only
> from an academic perspective. :)
> Brian, how are you integrating .Net into Fusion?  With a task pane
> application?  I wonder if there is a JavaScript function that returns
> the map ID?
> Jason
> From: Berdel, Brian
> Mike it actually does because I am able to use the featurereader...I
> just cannot open a map.  Anyone know how to get the ID?
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/.NET-Fusion-tp16722611p19698829.html
