[mapguide-users] Legend and runtime Layer filter
Matteo matteo.conte1979 at libero.it
Thu Apr 16 14:26:56 EDT 2009
Hi Kenneth,
  I have found the bug. The problem is on BuildLayerDefinitionData sub of Legend.aspx file. When the sub process a runtime layer the line doc.LoadXml(layerDefString) get a error. I solve the problem saving the xml definition of layer in a file and load it
The same problem there is in MapGuide Enterprise 2010 so I think also in MapGuide Open Source 2.1
Regards
Matteo
Have you tried with a subset of the filter? eg: only: callStatus like
'Completed'.
I have had trouble with composite filters on OGR datasources, but single
filters work fine.
The "valid = 01" part looks a little suspicious to me, is "valid" a
numeric or text column?
Regards, Kenneth Skovhede, GEOGRAF A/S
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Legend-and-runtime-Layer-filter-tp2249502p2643254.html
