[mapguide-users] Legend and runtime Layer filter
Matteo matteo.conte1979 at libero.it
Sun Apr 19 03:40:51 EDT 2009
Yes, the code add a "?" char before the "<?xml version="1.0" encoding="UTF-8"?>" line.
Regards,
Matteo
That would suggest that the data in the resource is invalid xml?
Have you tried to examine the layerDefString variable before the crash?
Regards, Kenneth Skovhede, GEOGRAF A/S
Matteo skrev:
> Hi Kenneth,
>   I have found the bug. The problem is on BuildLayerDefinitionData sub of Legend.aspx file. When the sub process a runtime layer the line doc.LoadXml(layerDefString) get a error. I solve the problem saving the xml definition of layer in a file and load it
> The same problem there is in MapGuide Enterprise 2010 so I think also in MapGuide Open Source 2.1
> Regards
> Matteo
> Have you tried with a subset of the filter? eg: only: callStatus like
> 'Completed'.
> I have had trouble with composite filters on OGR datasources, but single
> filters work fine.
> The "valid = 01" part looks a little suspicious to me, is "valid" a
> numeric or text column?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Legend-and-runtime-Layer-filter-tp2249502p2658472.html
