[mapguide-users] Mapguide studio with FDO Mysql provider
euskalmap ziburudebian at free.fr
Wed Apr 22 03:19:03 EDT 2009
Thanks for your response; i have resolved my problem : it is a problem from
configuration on my PC.
In another PC it run very well : i list the class objects of FDOProvider
thanks
Kenneth Skovhede, GEOGRAF A/S wrote:
> That is how Studio does it. If you change the datasource, it resets your
> layer.
> You can use Maestro to change the FeatureSource, but you have to
> manually check that
> your new FeatureSource has all the columns used in the layer setup.
> You can also just accept that the layer is reset, and set it up again.
> If the layer was non-modified when you began, I suggest you send a bug
> report to Autodesk.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> when i create a data connection (named Test_MySQL) like 'OSGEO FDO
>> Provider
>> for MySQL' (FDO 3.4) in Mapguide Studio 2.2, i have no problem :
>> i edit the IP address of my Debian (Sarge) server (with MySQL server 5),
>> the
>> name of bd, the user and password ==> the test connection is success.
>> But when i create a layer to this data connection , after choice the
>> featuresource 'Library://Ag Base/Donnee/Test_MySQL.FeatureSource', i have
>> this message :
>> 'You are about to select an incompatible data source. To continue and Re
>> to
>> initialize the copy with the default values'
>> the control of objects classes as a sign 'Be carreful' and the list of
>> objects classes is empty.
>> Have you an idea ?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Mapguide-studio-with-FDO-Mysql-provider-tp2670352p2674660.html
