[mapguide-users] select the location on map
susan Daniel daniel.susan6 at gmail.com
Wed Apr 22 03:46:08 EDT 2009
Thank u....
               Can i get the source code of any of these sample
applications? If so from where?
regards
susan
On Wed, Apr 22, 2009 at 1:00 PM, Ivan Milicevic
<Ivan.Milicevic at supranet.hr>wrote:
>  http://mapguide.osgeo.org/livegallery.html
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *susan Daniel
> *Sent:* Wednesday, April 22, 2009 8:06 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] select the location on map
> hi deve
>            I couldn't find that sample application.Any link?
> regards
> susan
> On Tue, Apr 21, 2009 at 8:01 PM, Dave Wilson <dave.wilson at autodesk.com>
> wrote:
> The sample application that does the Find Address does a selection on the
> map when you click on one of the search results. I thought this was
> discussed in the Sample Application.
> Dave
> *Sent:* Monday, April 20, 2009 12:18 AM
> hi alll...........
>                   I read the dev guide but didn't get any idea regarding
> this.Hav anyone tried this before pls give me any hint how to start this ...
> thanks &regards
> susan
> On Fri, Apr 17, 2009 at 8:18 PM, Dave Wilson <dave.wilson at autodesk.com>
> wrote:
> Have you read through the developer’s guide? It has sample code for
> selection and explains many concepts. It sounds like you need to make either
> an invoke script or invoke url call from a command in your Basic or Flexible
> Web Layout. You don’t actually have to replace the gettingstarted.php. In
> the invoke script or invoke url command allows you to specify the target
> frame for the output of the script.
> Regards,
> Dave
> *Sent:* Friday, April 17, 2009 3:57 AM
> yeah...i know that..
> On Fri, Apr 17, 2009 at 3:15 PM, Ivan Milicevic <
> Ivan.Milicevic at supranet.hr> wrote:
> Did you know how to create file that display's database table? If you don't
> know that you must find help somewhere else because I'm not a PHP guy.
> *Sent:* Friday, April 17, 2009 11:42 AM
> Hi..
>     No i dont have the file that displays database table...Actually iam
> doing this prjct in php.but i know javascript'
> On Fri, Apr 17, 2009 at 3:02 PM, Ivan Milicevic <
> Ok, so you have file that display's data from your database table? Or you
> don't have it at all? How familiar are you with javascript?
> *Sent:* Friday, April 17, 2009 11:13 AM
> hi...
>    My problem is that..
>    I have a database table..Having colums  place ,id etc .If i
> selected(clicking) a data in the table the corresponding place(polygon)
> should be displayed(selected) on the map...My map is a polygon map .each
> polygon having unique id.and the same id is present in the db table
> also....Now u got it?any idea please help...
> regards
> susan
> On Fri, Apr 17, 2009 at 2:24 PM, Ivan Milicevic <
> I'm not sure that I understand your problem. With this code you can select
> any feature on map. Can you send a little bit more information? I'm clues
> over there.
> *Sent:* Friday, April 17, 2009 10:47 AM
> thank you  ivan...
>                        on which file i have to write this coding???  any
> idea??
> regards
> susan
> On Fri, Apr 17, 2009 at 2:09 PM, Ivan Milicevic <
> OBJEKTI is layer name and other thing is path to the feature source.
> "Library://SAMPLES/DATA/SEWERS/SEWERS.FeatureSource");
> You can copy/paste feature source from mapguide maestro in layer definition
> window.
> *Sent:* Friday, April 17, 2009 9:45 AM
> thank you Ivan
> but  i 'd like to know on which file i want to write this coding??
> In ur coding OBJEKT1  is layer name right?then what is this
> "Library://PROJEKTI/" + TIMgisUser + "/PODACI/OBJEKTI.FeatureSource");
> thanks and regards
> susan
> On Fri, Apr 17, 2009 at 12:46 PM, Ivan Milicevic <
> Hello Susan,
> Here is C# code for selection, it's pretty same as PHP.
> MgSiteConnection siteConnection = null;
>     InitializeWebTier();
>     MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>     siteConnection = new MgSiteConnection();
>     siteConnection.Open(userInfo);
>     MgResourceService resourceService = siteConnection.CreateService(
> MgServiceType.ResourceService) as MgResourceService;
>     MgFeatureService featureService = siteConnection.CreateService(
> MgServiceType.FeatureService) as MgFeatureService;
>     MgMap map = new MgMap();
>     map.Open(resourceService, "1"); //opening map with name „1“
>     MgFeatureQueryOptions queryOptionsObjekti = new MgFeatureQueryOptions
>     MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
>     MgSelection selection = new MgSelection(map);
>     //Defining layer and feature source
>     MgLayer layerObjekti = GetLayerByName(map, "OBJEKTI");
>     MgResourceIdentifier featureResIdObjekti = new MgResourceIdentifier(
>     //Creating feature filter, this is very important step!
>     string filter = "ID=" + idO;
>     queryOptionsObjekti.SetFilter(filter);
>     MgFeatureReader featureReaderObjekti = featureService.SelectFeatures(
> featureResIdObjekti, "OBJEKTI", queryOptionsObjekti);
>     selection.AddFeatures(layerObjekti, featureReaderObjekti, 1);
>     selection.Save(resourceService, "1");
>     StringReader stream = new StringReader(selection.ToXml());
>     string selectionXml = selection.ToXml();
>     featureReaderObjekti.Close();
>     map.Save();
>     //Here, you call javascript function and pass the selection var
>     Response.Write("<script>select('" + selectionXml + "');</script>");
> //This is javascript function that set's the selection from code and do the
> refresh.
> function select(xml)
> parent.mapFrame.SetSelectionXML(xml);
> parent.mapFrame.ExecuteMapAction(10);
> *Sent:* Friday, April 17, 2009 9:11 AM
> *To:* mapguide-users at lists.osgeo.org
> *Subject:* [mapguide-users] select the location on map
> hi all
>         My plat form is mapguide maestro&php.I connect it with mysql.Now i
> want to select the corresponding polygon on the map while clicking on the
> data in database.In order to display the database table in the taskpane,i
> removed the contents of the file "/mapviewerphp/getting started .php" and
> wrote my codings.then how to select the polygon?.Any one know this????Anyone
> having coding to do this???
> please help me
> thanks&regards
>  susan
> mapguide-users mailing list
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
> thanks&regards
>  susan
thanks&regards
 susan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090422/4413fc48/attachment.html
