[mapguide-users] New Enterprise Mapguide Samples unable to download.
Andy Morsell amorsell at spatialgis.com
Fri Apr 24 17:10:32 EDT 2009
Thanks Chris.  I would prefer to go the Google layers overlaid on Fusion
route so will explore that further.  I was able to look at the index.html
file for the GoogleSlate template on the MapGuide Enterprise demo page and
it looks reasonably straight-forward.  I'll have to setup another test
environment and give it a whirl when I get a few free cycles.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Claydon
Sent: Friday, April 24, 2009 2:03 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] New Enterprise Mapguide Samples unable to
download.
Fusion 2.0 is supposed to support Google layers simply by adding them to the
ApplicationDefinition for the layout. I played with it a bit, but ran into
problems and then ran out of time. The Fusion developers are aware of the
issues, and I believe they are working on fixes. The samples that show
Google overlaid on Fusion take a slightly different approach by modifying
the templates and/or using InvokeScript commands to add/remove the Google
layers from the underlying OpenLayers map object used by Fusion. It is quite
easy to do with a few lines of JavaScript.
Chris.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Friday, April 24, 2009 2:54 PM
To: 'MapGuide Users Mail List'
download.
>From following the discussions here, it had sounded like those who had
tried
to get Google Maps layers integrated into flexible layouts did not have full
success.  I also installed Fusion 2.0b and had miscellaneous problems so I
reverted back to my most stable 1.0.1 with some manual fixes.  I did post
several Trac tickets so I hope those issues will be fixed in the release
version of 2.0.  At this point, while I generally enjoy dinking and trying
new things, I simply don't have time to play with some of these upcoming
features until full release versions of Fusion and MGOS and documentation on
the features are made available.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, April 24, 2009 1:29 PM
download.
I'm sure Mike, Paul, Chris or someone else that actually knows what they're
talking about will correct me if I'm wrong, but I'm pretty sure that if
you're willing to install Fusion 2.0 on your own, you should be able to make
it work with MapGuide 2.0.2.
Jason
Sent: April-24-09 12:02 PM
download.
The Flexible Web Layouts using Google Maps API is super cool and exactly
what many of us have been waiting for.  I'm looking forward to MGOS 2.1
being released in the near future so I can put this type of functionality
into production.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
