[mapguide-users] Regarding Shape file
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Aug 3 08:21:33 EDT 2009
The newer version of Maestro will upload these for you.
If you just point to the file, the other files will be in the folder
already, which is why it works.
I can assure you that having just the SHP file will not work.
http://en.wikipedia.org/wiki/Shapefile
See the overview:
While the term "shapefile" is quite common, a "shapefile" is actually a
set of several files.
Three individual files are normally mandatory to store the core data
that comprises a shapefile.
Regards, Kenneth Skovhede, GEOGRAF A/S
sathishpsk9 skrev:
> HI Kenneth Skovhede
> I found the extents of shp file using fdo connection ......... and set
> extents  ... still  new shape layer  doest not appear
> Just a thought, you are uploading all the required shp files right?
> like:
> file.shp
> file.dbf
> file.idx
> etc...
>  I do not upload all these other than shp files using maestro also but  they
> get dislayed
> Thanks & Regards
> Satish Kumar
