[mapguide-users] Problems with MGOS 2.1 test build 4114 and Fusion 2.0
GreenMapSanMiguel webmaster at SMAmap.com
Sun Aug 9 16:10:42 EDT 2009
GreenMapSanMiguel wrote:
> My application worked rather nicely on test build 2.1 b4090 except for a
> severe issue with FDO connections not being released.  This FDO problem
> appears to be resolved in test build 4114.  Unfortunately, I'm
> encountering some new problems.
> Selection issues:
> After loading the map and doing a search, selection of a feature
> (setSelection with zoom) works the first two times a feature is selected
> from the results list except that the selection is not highlighted.  The
> status bar and selection pane do correctly show that 1 feature is
> selected.  In previous builds the feature was highlighted correctly.
> The third and subsequent times a feature is selected, a series of pink
> boxes with an 'x' in the upper left corner (broken image link?) appear
> instead of the map.  Clicking on one of these boxes causes the map to
> reappear with the correct extents for the selected feature (but the
> feature still is not highlighted.)  Looks like it is trying to display a
> tiled map, but I am not using tiling.
> Background issue:
> The background image used during load is now showing through my map's
> background.  I display text using a transparent png on a green background
> while the map loads.  This same text now shows on my map's beige
> background when I zoom out far enough to see some of the background.  (The
> features obscure part of the text, it only appears where there are no
> features.)  Here's the css:
> #Map {
>   background-image: url("/images/map/mapLoading.png");
>   background-repeat:no-repeat;
>   background-position: center;
>   overflow: hidden;
>   z-index: 0;
>   background-color: #E8F39B;
>   border: 1px solid #404040;
> Overview map:
> This is also working diffently than before.  Sometimes the red-dotted
> selection box is not completely contained within the Overview Map pane.
> Please let me know if I can provide more information or do additional
> testing.
> Andy
View this message in context: http://n2.nabble.com/Problems-with-MGOS-2.1-test-build-4114-and-Fusion-2.0-tp3413762p3413979.html
