[mapguide-users] change selection color
Jackie Ng jumpinjackie at gmail.com
Tue Aug 11 08:25:22 EDT 2009
You shouldn't have to go that far. Changing templates requires at the most: a
web server restart, and at the least: a refresh of the web browser.
- Jackie
northtron wrote:
> You always need to stop/restart the MapGuide Service when you change a
> template file to see the results.
> saloua wrote:
>> hi !  i've read the documentation you gove me and tried to apply it for
>> changing selection color : format of my "ajaxmappane.templ" (or function
>> wich concerning me) is
>> i've tried to modify it by adding:
>> .....Math.random()+ "&BEHAVIOR=7&SELECTIONCOLOR=FF5300FF"; As
>> documentation
>> says, and when i try after to get my map on ajaxviewer it's not loaded
>> the
>> ajax viewer is loaded but page not contains my map!!!! i've changed
>> version
>> too (as documentation you sent me)
>> VERSION=1.0.0 to VERSION=2.0.0 but it doesn't give good result, if you
>> can
>> explain me why?? thanks in advance
View this message in context: http://n2.nabble.com/change-selection-color-tp3041849p3423580.html
