[mapguide-users] [ODBC provider] Select within
Dave Wilson dave.wilson at autodesk.com
Tue Aug 11 12:33:10 EDT 2009
Not that I know of.
This is a known limitation of the provider.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Hequet
Sent: Tuesday, August 11, 2009 9:01 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] [ODBC provider] Select within
i'm using the Select Within tool and i encountered a problem with Point on
ODBC layers:
the "select within tool" (and also the spatial operators used via API) does
not perform a "select within" operation but an "Envelope Intersects".
Can we bypass this?
thank you,
David
View this message in context: http://n2.nabble.com/-ODBC-provider--Select-within-tp3424323p3424323.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
