[mapguide-users] Problems with MGOS 2.1 test build 4114 and Fusion 2.0
GreenMapSanMiguel webmaster at SMAmap.com
Tue Aug 11 15:37:26 EDT 2009
Thanks Jason, I should have time to submit the others later today.  Also,
thanks for the information on custom single-files, I'll give it a try.
Andy
p.s. Your Nanaimo application looks great.   I can open up my application
http://greenmapsanmiguel.org/ to a wider audience now that I have a solution
for the FDO connection issue and will submit it as a Fusion 2 example.
[mailto:ml-user+57811-1764740187 at n2.nabble.com]
Sent: Tuesday, August 11, 2009 10:23 AM
To: GreenMapSanMiguel
Subject: RE: [mapguide-users] Problems with MGOS 2.1 test build 4114 and
Fusion 2.0
I have submitted this issue and potential fix to the Fusion trac on your
behalf:
http://trac.osgeo.org/fusion/ticket/275
Jason
-----Original Message-----
Sent: Sunday, August 09, 2009 1:22 PM
To: [hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3424536&i=0>
Subject: Re: [mapguide-users] Problems with MGOS 2.1 test build 4114 and
Fusion 2.0
I have resolved the OverviewMap issue.  In the previous release of
fusion/lib/OpenLayers/theme/default/style.css the
.olControlOverviewMapElement styling was commented out.  It was uncommented
in the new version causing the MapExtentRectangle to be off-center.
Commenting the styling out again fixes the problem:
.olControlOverviewMapElement {
/* modified for fusion
    padding: 10px 18px 10px 10px;
    background-color: #00008B;
    -moz-border-radius: 1em 0 0 0;
All of the other problems appear to be caused by changes within Fusion, not
Mapguide.  Running with the July 25 fusion single-file corrects them
(although the new legend.js is necessary for the legend to work correctly )
mapguide-users mailing list
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3424536&i=1>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
View message @
http://n2.nabble.com/Problems-with-MGOS-2.1-test-build-4114-and-Fusion-2.0-t
p3413762p3424536.html
To unsubscribe from Re: Problems with MGOS 2.1 test build 4114 and Fusion
2.0, click
< (link removed)
hcC5jb218MzQxNDAyNXw1MjQ3ODY4ODY=>  here.
View this message in context: http://n2.nabble.com/Problems-with-MGOS-2.1-test-build-4114-and-Fusion-2.0-tp3413762p3426367.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090811/15f832b8/attachment.html
