[mapguide-users] Creating a static image problem
Jo Cook j.cook at oxfordarch.co.uk
Wed Aug 12 11:40:05 EDT 2009
Dear All,
I am trying to implement the following:
The user selects a property (for example) from a drop-down list and is taken
to a page with more details, a thumbnail map of the location, and an option
to click on a link and go to the main map, where the property will be zoomed
and highlighted. The setup is MGOS 2.1 with apache and php.
I have managed to implement the second part, opening the main map page,
highlighting the property and zooming to it, with some judicious use of an
example posted elsewhere on the forum.
However, I'm stuck trying to implement the thumbnail image. I am using the
property report example from the developers guide as my starting point, and
using the same code that works for highlighting and zooming to create the
selection for the rendering service. So what I want to do is send the
parameters for the map, the scale, the coordinates etc, the selection and
the session to the createmapimage.php file from the developers guide. That
page fails with a resource not found error, pointing at the map resource
(Session:19bacd00-6982-102c-8000-00142acfcbee_en_7F0000010AFC0AFB0AFA//Map1.Map).
Here's the php for the file that sends off the selection:
$args = ($_SERVER['REQUEST_METHOD'] == 'POST') ? $_POST : $_GET;
$mapScale = 3000;
$imageHeight = 300;
$imageWidth = 300;
$SMAlayer = 'Events';
$SMAlocation = $args['PKEY'];
try
  if($SMAlayer && $SMAlocation) {
		$userInfo = new MgUserInformation("Anonymous", "");
		$siteConn = new MgSiteConnection();
	    $siteConn->Open($userInfo);
	    $site = new MgSite();
	    $site->Open($userInfo);
	    $sessionId = $site->CreateSession();
	    $userInfo->SetMgSessionId($sessionId);
	    $resourceSrvc =
$siteConn->CreateService(MgServiceType::ResourceService);
	    $map = new MgMap();
	    $resId = new MgResourceIdentifier("Library://Maps/Map1.MapDefinition");
	    $mapName = $resId->GetName();
	    $map->Create($resourceSrvc, $resId, $mapName);
	    $layers = $map->GetLayers();
	    $selLayer = $layers->GetItem($SMAlayer);
		$featureResourceId = new
MgResourceIdentifier($selLayer->GetFeatureSourceId());
		$featureClassName = $selLayer->GetFeatureClassName();
		$filter = "PKEY = $SMAlocation";
		echo $filter;
		$queryOptions = new MgFeatureQueryOptions();
		$queryOptions->SetFilter($filter);
	    $featureSrvc = $siteConn->CreateService(MgServiceType::FeatureService);
	    $featureReader = $featureSrvc->SelectFeatures($featureResourceId,
$featureClassName, $queryOptions);
	    $selection = new MgSelection($map);
		$selection->AddFeatures($selLayer, $featureReader, 1);
		$selectionXml = $selection->ToXml();
		print_r($selectionXml);
		  //get the coordinates for javascript zoom
		$geometryReaderWriter = new MgAgfReaderWriter();
		if($featureReader->ReadNext()) {
			$byteReader = $featureReader->GetGeometry("Geometry");
			$geometry = $geometryReaderWriter->Read($byteReader);
			$centerPoint = $geometry->GetCentroid();
			$mapCenterX = $centerPoint->GetCoordinate()->GetX();
          $mapCenterY = $centerPoint->GetCoordinate()->GetY();
          $sitecode = $featureReader->GetString('SITE_CODE');
catch (MgException $e)
  echo '<p>' . $e->GetMessage() . '</p>';
  echo '<p>' . $e->GetDetails() . '</p>';
$selectionEncoded = urlencode($selectionXml);
$imageUrl =
"./devguide/custom_output/createmapimage.php?SESSION=$sessionId&SELECTION=$selectionEncoded&MAPNAME=$mapName&SCALE=$mapScale"
"&HEIGHT=$imageHeight&WIDTH=$imageWidth&CENTERX=$mapCenterX&CENTERY=$mapCenterY";
This correctly picks up the scale, the coordinates, the sitecode etc.
createmapimage.php is un-modified from the base setup.
I'm very new to this, so I'm stuck trying to figure out what is wrong with
what I'm sending to createmapimage.php. If someone could help, I'd be very
grateful!
Thanks
Jo
View this message in context: http://n2.nabble.com/Creating-a-static-image-problem-tp3431631p3431631.html
