[mapguide-users] Change order of fields displayed in properties
pane?
Jo Cook
j.cook at oxfordarch.co.uk
Fri Aug 14 04:58:46 EDT 2009
It does? Which version? I am currently using the stable version, which is
playing hell with the properties- if I change the display name (and save) it
sets it back on reload, and none of my changes seem to persist to the
viewer. Come to think of it, I'm using a joined layer. Is this likely to be
compounding the issue?
Thanks
Jo
Kenneth Skovhede, GEOGRAF A/S wrote:
> Maestro supports ordering of the properties, but perhaps the viewer
> sorts them afterwards.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> James Card skrev:
>> On Thu, 13 Aug 2009 07:50:21 -0700, Jo Cook <j.cook at oxfordarch.co.uk>
>> wrote:
>>> Is it possible to specify the order in which fields are displayed in
>>> the properties pane? Currently it seems to display them in
>>> alphabetical order, rather than the order in which they appear in the
>>> data source. The only way I can think of getting round it at the
>>> moment is to number all of the properties, which will look a bit
>>> strange...
>> I don't know of any way to specify the sort order. The workaround we
>> use, rather than numbering the property names, is to insert leading
>> spaces in the property names. This causes them to be sorted according
>> to number of leading spaces, but since HTML collapses whitespace to a
>> single space the display still looks looks good.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Change-order-of-fields-displayed-in-properties-pane--tp3438480p3443840.html
