[mapguide-users] Change order of fields displayed in properties pane?
Jo Cook j.cook at oxfordarch.co.uk
Mon Aug 17 04:21:15 EDT 2009
Hi Jackie,
That did the trick, thanks.
Jo
Jackie Ng wrote:
> The properties are sorted before being displayed in the properties pane.
> You could try commenting out or removing the following line of code to see
> how things go.
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ#L2837
> - Jackie
> Jo Cook wrote:
>> Dear All,
>> Is it possible to specify the order in which fields are displayed in the
>> properties pane? Currently it seems to display them in alphabetical
>> order, rather than the order in which they appear in the data source. The
>> only way I can think of getting round it at the moment is to number all
>> of the properties, which will look a bit strange...
>> Thanks
>> Jo
View this message in context: http://n2.nabble.com/Change-order-of-fields-displayed-in-properties-pane--tp3438480p3457213.html
