[mapguide-users] Numeric Search
Andy Morsell amorsell at spatialgis.com
Wed Aug 26 17:07:45 EDT 2009
If you build the query with the expression builder in Autodesk Studio as
part of a Fusion search widget, I can confirm that the following syntax
works on my end with a numeric field (PRIMARYINDEX):
ToString( PRIMARYINDEX ) LIKE '%$USER_VARIABLE%'
Try stripping out all of the fields in your search results and only include
the one you are searching on to see if that makes a difference.
Andy Morsell, P.E.
Spatial Integrators, Inc.
47° 46' N 116° 49' W
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark Hedges
Sent: Wednesday, August 26, 2009 1:40 PM
To: dave.wilson at autodesk.com; mapguide-users at lists.osgeo.org
Subject: SPAM-LOW: Re: [mapguide-users] Numeric Search
Dave I tried your syntax and still end up with the "The character '$' is
invalid.
To: List, MapGuide Users Mail <mapguide-users at lists.osgeo.org>
Sent: 8/26/2009 1:35:02 PM
Subject: RE: [mapguide-users] Numeric Search
correct me if I'm wrong, but shouldn't the full syntax be:
ToString(FID) LIKE Concat(ToString($USER_VARIABLE), '%')
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Wednesday, August 26, 2009 2:32 PM
To: MapGuide Users Mail List
Are you by chance using dotnet instead of php?
Sent: Wednesday, August 26, 2009 4:29 PM
To: mapguide-users at lists.osgeo.org
Thank you for reply.  I have tried this code along with several others and
still no luck.  This now gives me an invalid character error message for the
$.  I will keep trying.
Traian Stanev wrote:
> Try something like:
> FID LIKE Concat(ToString($USER_VARIABLE), '%')
> Traian
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> Sent: Wednesday, August 26, 2009 2:52 PM
>> Subject: [mapguide-users] Numeric Search
>> I have created several searches like PROJECT_TITLE LIKE
>> '%$USER_VARIABLE%'
>> which works great.  The data in the Project_Title table is not Numeric.
>> When I try to create a search for a Numeric field such as FID LIKE
>> '%$USER_VARIABLE%' I get the following message: "Arguement types for
>> operator 'LIKE' are mismatched.  The validation operation expected
>> 'Boolean'
>> but the expression returned 'Unknown".  It appears that I cannot use this
>> expression on Numeric data.  Any help would be greatly appreciated.
>> View this message in context: http://n2.nabble.com/Numeric-Search-
>> tp3518680p3518680.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://n2.nabble.com/Numeric-Search-tp3518680p3519257.html
