[mapguide-users] Converting dwg into shp
Mark Hedges hedgesm at cityofnorthlasvegas.com
Fri Aug 28 15:04:33 EDT 2009
Do you have FME by Safe Software?  FME is a great program for doing file type
conversions.  You can also set up Scheduled Tasks to perform at a given time
or do a batch conversion of dwg to shp.
Hope this helps,
Mark
Thomasch wrote:
> Hi,
> is there a way to convert dwg into shp in a batch? I've got some
> drawings with many layers and would like to have at least one shp per
> layer. I tried Autodesk Map - which is pretty good, but there i din't
> find any batch mode.
> Thanks
> Thomasch
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Converting-dwg-into-shp-tp3536728p3536761.html
