[mapguide-users] EPSG:3785 (Popular Visualisation CRS / Mercator) in MGOS 2.1
Dave Wilson dave.wilson at autodesk.com
Fri Dec 11 13:01:42 EST 2009
A quick test with the web tier test pages http://servername/mapguide/mapagent/index.html , using the Coordinate System API and entering your EPSG code into ConvertEpsgCodeToWkt shows that this wkt is not recognized. You should use the map editor in Maestro or Studio to select a new coordinate system and find out the Mentor code for an equivalent to your EPSG code (assuming there is one).
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser Burgess
Sent: Friday, December 11, 2009 9:26 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] EPSG:3785 (Popular Visualisation CRS / Mercator) in MGOS 2.1
I had a map that was projected in UTM NAD83 Zone 17 and the display seemed to be fine.   I then used the set resource from the map agent and converted the map to EPSG:3785 (Popular Visualisation CRS / Mercator).  This was done using the release 2.1
Now when I preview the map in MGE2010 studio nothing displays and when I load the map into a fusion template nothing will display.
Any ideas?  Is this projection not supported by MGOS2.1?
Fraser
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091211/b1b1cfe4/attachment.html
