[mapguide-users] the coordinate points is shown in different locations when i use differnt map server??
Zac Spitzer zac.spitzer at gmail.com
Mon Dec 21 09:38:51 EST 2009
so even after the move to the new co ordinate system library,
the most popular projection on the web requires a manual
edit in the latest mapguide? surely not?
2009/12/22 Jackie Ng <jumpinjackie at gmail.com>:
> Google/Bing/Yahoo maps use the same mercator projection. Your map needs to be
> in the same projection information. MapGuide can re-project your layers on
> the fly.
> You can find the WKT for the projection here:
> http://trac.osgeo.org/fusion/wiki/MapGuideCommercialOverlays
> - Jackie
> leena wrote:
>> hello everyone ;
>> i have a coordinates data which are supposed to be located in Dubai city;
>> when i try to view the coordinate locations in google map or any other map
>> server (yahoo ...etc)
>> the locations are shown in another city ????
>> but when i try to few the data with "transcad" it shows the exact correct
>> locations in Dubai city????
>> now my question is that if i wanna use mapGuide or google map to few the
>> same data shall i make some
>> conversion to the coordinate data to be viewed on them instead of
>> transcad????
>> thanks in advance;
> View this message in context: http://n2.nabble.com/the-coordinate-points-is-shown-in-different-locations-when-i-use-differnt-map-server-tp4196895p4197664.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
