[mapguide-users] RE: Best way to migrate users?
Trevor Wekel trevor_wekel at otxsystems.com
Mon Dec 28 12:06:50 EST 2009
Hi Martin,
Try the web extensions API methods MgSite.EnumerateUsers and MgSite.AddUser.  EnumerateUsers is fully supported.  AddUser is export to .Net/PHP/Java but not officially supported.  If EnumerateUsers returns the password, you should be all set.  You can glean a lot of information from header files...
http://trac.osgeo.org/mapguide/browser/branches/2.1/MgDev/Common/MapGuideCommon/Services/Site.h
If you have any group memberships, EnumerateGroups and GrantGroupMembershipsToUsers may also be helpful.
EnumerateRoles and GrantRoleMembershipsToUsers will also be helpful if you are making use of multiple roles.
 I don't know if an MGP export will work correctly with user accounts propagated in this manner.  I suspect the export strips out all the permissions.
(Shameless plug) If you're not keen on writing all this script, I can give you a quote for it and contribute it back to the community.  Ping me be email if you are interested.
Thanks,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: December 28, 2009 9:17 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Best way to migrate users?
What is currently the best way to migrate users and their passwords from MG 2.02 to 2.1?  I do not want to copy over the site directories if possible.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540-345-1410
gis.edsi.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091228/82032af7/attachment.html
