[mapguide-users] Confused about config.json for Fusion
Jackie Ng jumpinjackie at gmail.com
Tue Dec 29 23:34:40 EST 2009
I would guess that they are mapserver settings.
Fusion is also a framework for mapserver
- Jackie
GreenMapSanMiguel wrote:
> I have a couple of Fusion applications in production but realize (oops!)
> that I have never updated the default config.json file.  Everything seems
> to be working fine, but would this affect performance?  It doesn't appear
> (to me) that these parameters are being used.
> I'm particularlly confused as to what to set for the following two
> parameters, which are currently the defaults:
> "temporaryDirectory": "/ms4w/tmp"
> "tileCacheUrl": "http://localhost:8008/sheboygan"
> It doesn't look like the temporaryDirectory is being used, there is no
> folder ms4w created anywhere on my system.  Should I create a special one
> for Fusion?  Would the url be relative to 'www'?
> My MapGuide tiles are stored in
> MapGuide/Server/Repositories/TileCache/(mapname)/...  Does there need to
> be another folder for Fusion's tile cache?
> Thanks for any suggestions for how to set these parameters in the
> config.json.
> Andy Baltimore
View this message in context: http://n2.nabble.com/Confused-about-config-json-for-Fusion-tp4228933p4230856.html
