[mapguide-users] SQL 2008, MGOS 2.0.2, FDO 3.3.x - 3.4.x, Maestro 1.0.9 do not cooperate
carls carlshe at 163.com
Sun Feb 1 08:22:50 EST 2009
Maybe follow link can help you.
http://n2.nabble.com/Maestro%3A-can%27t-find-the-table-containing-the-geometry-field-with-SQLServerSpatial-td1818596.html#a1818607
miansi wrote:
> Hello,
> I am newbe in this area and I am trying to marry SQL 2008 with MGOS.
> I used this topic to do transfer from SHP to SQL
> http://www.longhorncorner.com/UploadFile/nschan/Shapefiles04112007005648AM/Shapefiles.aspx
> Last Friday everything was fine and I was able to see my data on the map.
> Then something happens :-) and I wasn't able to see data from SQL on the
> map anymore.
> To eliminate environment-related issues I started from scratch and
> installed new MGOS 2.0.2 server and the story begins...
> The way I was changing FDO was stop MapGuide Server service, delete
> everything from C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO and
> replace it with files from fdosdk-win32-3.3.1\Bin or
> fdosdk-win32-3.3.2\Bin and so on. So I was using Windows SDK files.
> Using FDO 3.4.0.Beta1 through FDO 3.3.2 allows me to create DataSource,
> which points to my SQL Server database, but gives me "Failed to read
> schema from data source. The operation gave the error message: Bad
> document" when I am trying to choose Feature Source while creating layer
> in MapGuide Maestro (both v1.0.9 and r3558). Out of the box.
> Using FDO 3.3.1 allows me to create DataSource and Layer, but shows no
> data on the map even though I know that there is data in the table and I
> can see it on the Spatial Results tab in the SQL. I check that my Initial
> Map View set to the right values.
> Next step for me would be to try installing Autodesk MapGuide Studio trial
> and using FDO SQL 2008 spatial provider from there...
> But before I would do so I have a question.
> Is there checklist of components/requirements defined and tested for MGOS
> <-> SQL 2008 integration?
> Like
> 1. PK in the table has to be int/bigint/...
> 2. Geometry column has to have a clustered index
> 3. FDO has to be version ...
> 4. Maestro ...
> Any help would be greatly appreciated.
> Thank you!
Regards, Carl SHE
View this message in context: http://n2.nabble.com/SQL-2008%2C-MGOS-2.0.2%2C-FDO-3.3.x---3.4.x%2C-Maestro-1.0.9-do-not-cooperate-tp2247138p2253780.html
