[mapguide-users] Thematic Mapping
padmini godavarthi godavarthi.padmini at gmail.com
Sun Feb 1 23:22:29 EST 2009
Hi z,
Thanku very much for ur suggestions.i will respect it.
but i understood the answer given by Chris.
But i think its not correct solution for my original query.
i want to display different colors to the different polygons.
but while applying 2 colors in the InterpolateColor function it doesn't
change in different colors
 while (dataReader.ReadNext())
                value = GetFeaturePropertyValue(dataReader, "FeatId");
                filterText = """ + "FeatId" + "" = ";
                    filterText = filterText + value;
                areaRuleXML = String.Format(areaRuleTemplate,
                                          "FeatId" + ":" + value,
                                            filterText,
InterpolateColor(portion, "C2C3C4", "C2C3C4", 0), InterpolateColor(portion,
"000000", "000000", 0));
                areaDoc = new XmlDocument();
                areaDoc.LoadXml(areaRuleXML);
                areaDoc.Save("C:\\theme.xml");
                areaNode = doc.ImportNode(areaDoc.DocumentElement, true);
                areaTypeStyle.AppendChild(areaNode);
             portion = portion + increment;
it displays some yash color to all the polygons,but i want different color
Can u plz help me
Thanks and Regards,
Padmini G.
zspitzer wrote:
> when someone takes times to provide a response, it's respectful to taking
> a bit more time to read your original email AGAIN !
> your calling
> InterpolateColor(portion,"C2C3C4", "C2C3C4", 0));
> which takes two colors to create a range, yet you pass in the same
> color twice....
> sorry if I sound a bit grumpy, but it appears that Chris spent more
> time reading
> your email that you did after his reply....
> z
> On Sat, Jan 31, 2009 at 7:57 PM, padmini godavarthi
> <godavarthi.padmini at gmail.com> wrote:
>> Hi,
>> Thanks for ur reply.but i didn't get u
>> can u plz tell me briefly so that it will be helpful to me.
>> Thanks and Regards,
>> Padmini.
>> Chris Claydon wrote:
>>> I would recommend modifying your call to InterpolateColor() so that the
>>> start color and end color correspond to the colors you want. They are
>>> currently both set to the same string.
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>>> godavarthi
>>> Sent: Friday, January 30, 2009 3:59 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] Thematic Mapping
>>> Hi,
>>> iam using mpguide opensource 2.0 (.net 2.0 +IIS 5.1).
>>> I want to do thematic mapping for polygon layer(for example parcel
>>> layer)
>>> i tried to use the code in dotnetviewer sample.its working fine
>>> iam able to create a thematic layer with same color to the all polygons.
>>> Now my problem is that i want to apply different colours to the
>>> different
>>> polygons
>>> for example for parcel_id =1   ------------ green colour
>>> for example for parcel_id =2   ------------ Red colour and
>>> soon.........................
>>> for this can u plz tell me the code for how to do it?
>>> my code was as follows
>>> NameValueCollection serverVars = Request.ServerVariables;
>>>         String strServerVars = "";
>>>         foreach (String str in serverVars.AllKeys)
>>>             strServerVars += "<br>" + str;
>>>         String platform = serverVars["SERVER_SOFTWARE"];
>>>         String queryStr = serverVars["QUERY_STRING"];
>>>         string queryStr1 = serverVars["Form"];
>>>         NameValueCollection requestParams = Request.HttpMethod == "POST"
>>> Request.Form : Request.QueryString;
>>>         String sessionId = Request.QueryString["SESSION"];
>>>         string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
>>>         String configPath = realPath + "webconfig.ini";
>>>         MapGuideApi.MgInitializeWebTier(configPath);
>>>         MgUserInformation userInfo = new MgUserInformation(sessionId);
>>>         MgSiteConnection siteConnection = new MgSiteConnection();
>>>         siteConnection.Open(userInfo);
>>>         MgResourceService resourceService =
>>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>>>         MgFeatureService featureService =
>>> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>>>         MgMap map = new MgMap();
>>>         map.Open(resourceService, "mapdata");
>>>         MgLayerCollection layers = map.GetLayers();
>>>         MgLayer layer = (MgLayer)layers.GetItem("property layer");
>>>         MgResourceIdentifier resId = new
>>> MgResourceIdentifier(layer.GetFeatureSourceId());
>>>         MgResourceIdentifier layerDefResId = layer.GetLayerDefinition();
>>>         MgByteReader byteReader =
>>> resourceService.GetResourceContent(layerDefResId);
>>>         // Load the Layer Definition and Navigate to the specified
>>> <VectorScaleRange>
>>>         XmlDocument doc = new XmlDocument();
>>>         String xmlLayerDef = byteReader.ToString();
>>>         doc.LoadXml(xmlLayerDef);
>>>           XmlNodeList nodeList =
>>> doc.GetElementsByTagName("VectorScaleRange");
>>>     XmlElement vectorScaleRangecElement = (XmlElement)nodeList.Item(0);
>>>         XmlElement areaTypeStyle =
>>> (XmlElement)vectorScaleRangecElement.GetElementsByTagName("AreaTypeStyle").Item(0);
>>>         // Remove any existing <AreaRule> elements.
>>>         XmlNodeList areaRuleList =
>>> areaTypeStyle.GetElementsByTagName("AreaRule");
>>>         int count = areaRuleList.Count;
>>>         for (int i = 0; i < count; i++)
>>>             //The areaRuleList shrinks as we remove items, so always
>>>             //remove the first item (don't use the index i)
>>>             areaTypeStyle.RemoveChild(areaRuleList.Item(0));
>>>         // Now create the new <AreaRule> elements.
>>>         String areaRuleTemplate =
>>> File.ReadAllText(GetThemeXmlTemplatePath());
>>>         MgFeatureAggregateOptions aggregateOptions = new
>>> MgFeatureAggregateOptions();
>>>         String value = null;
>>>         String filterText = null;
>>>         String areaRuleXML = null;
>>>         XmlDocument areaDoc = null;
>>>         XmlNode areaNode = null;
>>>         double portion = 0.0;
>>>             aggregateOptions.AddFeatureProperty("FeatId");
>>>             aggregateOptions.SelectDistinct(true);
>>>                     aggregateOptions.SetFilter(totquery);
>>>                   double increment = (5 > 1) ? 1.0 / (5 - 1) : 1.0;
>>>             MgDataReader dataReader =
>>> featureService.SelectAggregate(resId,
>>> layer.GetFeatureClassName(), aggregateOptions);
>>>                 filterText = "&quot;" + "FeatId" + "&quot; = ";
>>>                                             filterText,
>>> true);
>>>             dataReader.Close();
>>>         // Now save our new layer definition to the session and add it
>>> to
>>> the map.
>>>         String xmlString = doc.DocumentElement.OuterXml;
>>>         String uniqueName = this.MakeUniqueLayerName(map, "property
>>> layer",
>>> "sample");
>>>         String legendLabel = layer.GetLegendLabel();
>>>         if ("sample".Length > 0)
>>>             legendLabel = legendLabel + " (" + "sample" + ")";
>>>         MgResourceIdentifier layerResId = new
>>> MgResourceIdentifier("Session:" + sessionId + "//" + uniqueName +
>>> ".LayerDefinition");
>>>         resourceService.SetResource(layerResId, new
>>> MgByteReader(xmlString,
>>> "text/xml") , null);
>>>         MgLayer newLayer = new MgLayer(layerResId, resourceService);
>>>         newLayer.SetName(uniqueName);
>>>         newLayer.SetLegendLabel(legendLabel);
>>>         newLayer.SetDisplayInLegend(layer.GetDisplayInLegend());
>>>         newLayer.SetVisible(true);
>>>         newLayer.SetSelectable(layer.GetSelectable());
>>>         layers.Insert(layers.IndexOf(layer), newLayer);
>>>         map.Save(resourceService);
>>>         return uniqueName;
>>>  private String InterpolateColor(double portion, String startColor,
>>> String
>>> endColor, int percentTransparent)
>>>         int alpha = (int)(255 * (100.0 - percentTransparent) / 100.0);
>>>         String result = "";
>>>         if (startColor.Equals(endColor))
>>>             result = String.Format("{0:X2}{1}", alpha, startColor);
>>>         else
>>>             int red = CalculateRGB(portion, startColor.Substring(0, 2),
>>> endColor.Substring(0, 2));
>>>             int green = CalculateRGB(portion, startColor.Substring(2,
>>> 2),
>>> endColor.Substring(2, 2));
>>>             int blue = CalculateRGB(portion, startColor.Substring(4, 2),
>>> endColor.Substring(4, 2));
>>>             result = String.Format("{0:X2}{1:X2}{2:X2}{3:X2}", alpha,
>>> red,
>>> green, blue);
>>>         return result;
>>>     private String MakeUniqueLayerName(MgMap map, String layerName,
>>> String
>>> themeName)
>>>         String desiredName = "_" + layerName + themeName;
>>>         String uniqueName = desiredName;
>>>         int index = 1;
>>>         while (map.GetLayers().Contains(uniqueName))
>>>             uniqueName = desiredName + index.ToString();
>>>             index++;
>>>         return uniqueName;
>>>     private int CalculateRGB(double portion, String startRGB, String
>>> endRGB)
>>>         double result = Int32.Parse(startRGB, NumberStyles.HexNumber) +
>>> portion * (Int32.Parse(endRGB, NumberStyles.HexNumber) -
>>> Int32.Parse(startRGB, NumberStyles.HexNumber));
>>>         return (int)result;
>>>     String GetThemeXmlTemplatePath()
>>>         String xmlTemplatePath ="D:\\arearuletemplate.xml";
>>>         return xmlTemplatePath;
>>> can u plz tell me the solution?
>>> Regards,
>>> Padmini.
>>> View this message in context:
>>> http://n2.nabble.com/Thematic-Mapping-tp2244230p2244230.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Thematic-Mapping-tp2244230p2249312.html
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Thematic-Mapping-tp2244230p2256479.html
