[mapguide-users] Legend and runtime Layer filter
Zac Spitzer zac.spitzer at gmail.com
Mon Feb 2 02:46:19 EST 2009
i'm happy to test the php stuff out, i guess we will need a mgp as well?
z
On Mon, Feb 2, 2009 at 6:42 PM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> I have created a seperate ticket with the patch, and noted this on the
> original ticket.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
> Kenneth,
> if your suggested cpp patch works, can you upload a diff?
> z
> On Mon, Feb 2, 2009 at 4:36 AM, Kenneth Skovhede, GEOGRAF A/S
> Yes, but since the bug is not yet fixed, it is also present in 2.0.2.
> Matteo skrev:
> Hi,
>   thanks for the answer. The bug is about 1.2 version of mapguide but i work
> with 2.0.2 version.
> Regards, Matteo
> Kenneth Skovhede, GEOGRAF A/S wrote:
> That is unfortunately a long standing bug:
> http://trac.osgeo.org/mapguide/ticket/167
> You must manually itterate all layers in the layerdefinition,
> and add the information to the runtime map after startup.
> Matteo skrev:
> Hi All,
>   I have some Layer Groups that are hidden when Map is load. When I
> active
> the layer group I apply a filter runtime (change the layerdefinition of
> the
> layers) to the Layers of group, set the legend visibility of group at
> true,
> and refresh the map. I see the objects in the map but I don't see the
> group
> in the legend.
> If I don't set a filter to the layers I see the group in the legend.
> Why?
> Can you help me?
> Thanks
> Matteo
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
