[mapguide-users] Integration with Google Earth
Sergio Nistal Calvo serginistal at hotmail.com
Tue Feb 3 11:34:53 EST 2009
Hi again,
I tried with "web tier test page" but it opens a window with a dialog box to download the file "mapagent.fcgi" (I suppose that it will be for php or something). Where can I download the ArcMap? (files to convert are cyl_mun_25.dbf, cyl_mun_25.idx, cyl_mun_25.shp and cyl_mun_25.shx (municipal boundaries), espacios.dbf, espacios.idx, espacios.shp, espacios.shx, espacios.sbn and espacios.sbx (natural areas) and vias.dbf, vias.idx, vias.shp and vias.shx (roads), in total 17.4 MB).
Date: Tue, 3 Feb 2009 00:07:36 +0200From: s.dalakov at mapware.netTo: mapguide-users at lists.osgeo.orgSubject: Re: [mapguide-users] Integration with Google EarthHi,Have you tried with ArcMap ? Or perhaps you could try to convert a mapguide layer to KML using web tier test page - http://localhost:8008/mapguide/mapagent/index.html ?I have converted several files with both methods and it works. It was some time ago, but I remember there was a problem in transformation if the coordinate system of the layer is not Decmal degrees (lat/lon) on WGS 84If it is a single file and you need just the KML output, I can try converting it for youStefan DalakovSergio Nistal Calvo wrote:
Hi, I´m trying to convert some data in shp format to kml format with Shp2kml program and I have two problems: 1 - one of the data, I can´t convert because the attribute is "too long, > 100 characters (240)", 2 - opening the other data with Google Earth, I get the map upside down, as if seen with a mirror, and displaced a few meters/kilometers on the right. The coordinate system of the data is LOCAL_CS ["Non-Earth (Meter)", LOCAL_DATUM ["Local Datum", 0], UNIT ["Meter", 1], AXIS ["X", EAST], AXIS [" Y", NORTH]], but I can´t get it shp2kml so I leave the default "WGS 1984 Global Definition" and I put "projected UTM (meters), Northern Hemisphere, UTM Zone 32". Any help is appreciated. Thanks.
El doble de diversión: Con Windows Live Messenger comparte fotos mientras hablas.
mapguide-users mailing list
Consigue gratis el nuevo Messenger. ¡Descárgatelo!
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090203/7c2071e2/attachment.html
