[mapguide-users] Integration with Google Earth
Stefan Dalakov s.dalakov at mapware.net
Wed Feb 4 12:22:02 EST 2009
Hi Rodolfo,
we are going a bit aside here from MGOS. I use  ArcMap 9.3 and the tool
is located in ArcToolBox->ConversionTools->ToKML->Layer to KML
Stefan Dalakov
Rodolfo Moreno wrote:
> Hi Stefan, which version of arcmap converts shp to kml?
> I have arcmap 9.2 and I have not found this tool.
> Thanks in advance,
> Stefan Dalakov wrote:
>> Hi,
>> If you save that file -mapagent.fcgi in fact you will save the output of
>> this module, i.e. the requested kml/kmz file. However it might be
>> windowed this kml file - it will contain part of the layer and will try
>> to open it dynamically when you move around in Google Earth, but this
>> will for sure contain the kml file.
>> The simplest perhaps will be to send me these files. You can zip and
>> send to my e-mail - I will use ArcMap to convert - it takes a couple of
>> minutes.Please add some info about coordinate system. ArcMap is an ESRI
>> product, and is not free. AT ALL!
>> Stefan Dalakov
>> Sergio Nistal Calvo wrote:
>>> Hi again,
>>> I tried with "web tier test page" but it opens a window with a dialog
>>> box to download the file "mapagent.fcgi" (I suppose that it will be
>>> for php or something). Where can I download the ArcMap? (files to
>>> convert are cyl_mun_25.dbf, cyl_mun_25.idx, cyl_mun_25.shp and
>>> cyl_mun_25.shx (municipal boundaries), espacios.dbf, espacios.idx,
>>> espacios.shp, espacios.shx, espacios.sbn and espacios.sbx (natural
>>> areas) and vias.dbf, vias.idx, vias.shp and vias.shx (roads), in total
>>> 17.4 MB).
>>> Thanks.
>>> Date: Tue, 3 Feb 2009 00:07:36 +0200
>>> From: s.dalakov at mapware.net
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: Re: [mapguide-users] Integration with Google Earth
>>> Hi,
>>> Have you tried with ArcMap ? Or perhaps you could try to convert a
>>> mapguide layer to KML using web tier test page -
>>> http://localhost:8008/mapguide/mapagent/index.html ?
>>> I have converted several files with both methods and it works. It was
>>> some time ago, but I remember there was a problem in transformation if
>>> the coordinate system of the layer is not Decmal degrees (lat/lon) on
>>> WGS 84
>>> If it is a single file and you need just the KML output, I can try
>>> converting it for you
>>> Stefan Dalakov
>>>     Hi,
>>>     I´m trying to convert some data in shp format to kml format with
>>>     Shp2kml program and I have two problems: 1 - one of the data, I
>>>     can´t convert because the attribute is "too long, > 100 characters
>>>     (240)", 2 - opening the other data with Google Earth, I get the
>>>     map upside down, as if seen with a mirror, and displaced a few
>>>     meters/kilometers on the right. The coordinate system of the data
>>>     is LOCAL_CS ["Non-Earth (Meter)", LOCAL_DATUM ["Local Datum", 0],
>>>     UNIT ["Meter", 1], AXIS ["X", EAST], AXIS [" Y", NORTH]], but I
>>>     can´t get it shp2kml so I leave the default "WGS 1984 Global
>>>     Definition" and I put "projected UTM (meters), Northern
>>>     Hemisphere, UTM Zone 32".
>>>     Any help is appreciated.
>>>     Thanks.
>>>     El doble de diversión: Con Windows Live Messenger comparte fotos
>>>     mientras hablas.
>>>     <http://www.microsoft.com/windows/windowslive/messenger.aspx>
>>>     _______________________________________________
>>>     mapguide-users mailing list
>>> <mailto:mapguide-users at lists.osgeo.org>
>>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Con el nuevo Windows Live lo tendrás todo al alcance de tu mano
>>> <http://home.live.com/>
> Rodolfo Moreno
> CivilEng
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090204/afa2ecd4/attachment.html
