[mapguide-users] Connecting to WMS
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 5 02:41:32 EST 2009
Since a WMS layer is a raster layer, MapGuide requires that the
Coordinate System of the layer is EXACTLY the same as for the map.
This means that the Coordinate System Override on the layer must match
the map's Coordinate System exactly.
To see if there are any errors reported, look in the error log:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
Regards, Kenneth Skovhede, GEOGRAF A/S
Stefan Dalakov skrev:
> Hi all,
> I am trying to add a WMS layer to my map.
> I followed the procedure described here :
> https://trac.osgeo.org/fdo/wiki/FdoWmsNotes
> to create a feature source.
> When I open the feature source in Studio the connection tests OK.
> Clicking the *Refresh* button generates an error originating from
> displayschema.php at line :
> /document.getElementById("Geom_"+"RissaWMS").previousSibling.firstChild.src
> = "./images/collapse_pane.png";
> /for each layer in the WMS feature source which is not critical
> (critical for Studio)
> *View Data *link then reports BBOX parameter missing, which I assume
> is normal
> I create a Layer afterwards, based on this Feature Source. The layer
> seems ok - refreshes OK, nothing on screen . This I also assume normal
> as  the layers (as described in the  GetCapabilities document)  are
> limited to scale ranges  up to 1:5000.
> I add this layer to an existing map, with matching coordinate system
> (EPSG:32632 of the WMS Feature Source and UTM-WGS84 / Zone 32 North of
> the map).
> The WMS layer is not shown on the preview in Studio - perhaps this is
> also normal - my other raster layers are not previewed either.
> But when I don't see the layer data in browser I am really stressed.
> And my biggest stress is based on the fact that I do not know how to
> debug this situation
> Any help will be highly appreciated
> Thank you in advance : Stefan Dalakov
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090205/8d81a949/attachment.html
