[mapguide-users] Repository or server error
Rodolfo Moreno rmoreno at voxiva.com
Thu Feb 5 15:16:27 EST 2009
Thanks Kenneth, I was a silly I forgot to review the log file.
this is the error in the log file.
Error: An exception occurred in FDO component.
        RDBMS: No current open database.
The error is being raised by feature sources with feature joins to SQL 2008
(my trial version has expired).
Describing the problem:
- Municipalities.FeatureSource has 2 featsources:
- Municipalities and MunicipalitiesExtension (It has featurejoins).
- Layer1 uses Municipalities (not MunicipalitiesExtension)
- Layer1 is used in Map1, then Map1 raise the RDBMS error.
I thought that only in the case that MunicipalitiesExtension is used the
error would be raised (although I guess that it should be like I was
thought)
I guess that it solved my problem, However I don't how why some of my maps
don't work well, even if these are not using layers with feature joins. For
example before that the expiration date of my SQL, these maps worked good in
both IE7 and FF2, and now these maps only are work good in FF2 and not in
IE7.
It's happennig with Fusion 1.0.6 (raise AJAX ERROR) and in the mapguide log
any error is registered. the ajax viewer is working good in both browsers.
I am really confused, could the SQL expiration has generated the FUSION
error?
Regards,
Kenneth Skovhede, GEOGRAF A/S wrote:
> What does the error log state:
> C:\Program Files\MapGuideOpenSource2.0\Server\Logs\Error.log
> If you can create a MapGuide Package, you can do this:
> 1. Create MapGuide Package
> 2. Move the package outside the install dir.
> 3. Uninstall MapGuide
> 4. Delete the installation folder
> 5. Re-install MapGuide
> 6. Restore the package
> That should clear any corruption in the repository.
> I doubt that the repository is the problem though.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rodolfo Moreno skrev:
>> Hi all,
>> I am having an odd issue.
>> the problem consists in that the server doesn't send the maps how if
>> these
>> did not exist, however when I access to my repository by Maestro or
>> Studio2009 I can see and edit all the resources of my repository.
>> the events before that the server or repository started to fail are:
>> - I was editing my resources using mapguide maestro and mapguide studio
>> 2009
>> at the same time.
>> - My SQL 2008 trial version has expired today (some of my datasources are
>> stored there). But I have tested another map that doesn't use data from
>> SQL
>> and the application doesn't work.
>> current efects:
>> - the majority of the times the applications(using these resources) don't
>> work but sometimes these work. (very odd).
>> I have restarted the server twice and the error keep on. I guees that for
>> some reason the repository has been corrupted. So I was looking for a
>> tool
>> that allows to repair the repository in REPOSITORYADMIN directory without
>> successful, becuase the tools within of that directory are for restoring.
>> or maybe it to be a server error?
>> any help will be appreciated,
>> Rodolfo Moreno
>> CivilEng
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Repository-or-server-error-tp2265645p2277008.html
