[mapguide-users] Working with state plane data in Mapguide studio
clarkie342 f2000342 at gmail.com
Thu Feb 5 18:44:10 EST 2009
I see the feature when I export it to shp and open it in arcmap.
attached in another layer from the DWG which shows up in Civil 3D but is
distorted in Mapguide studio. It also does not let me select features or
zoom properly.
Mark Pendergraft wrote:
> Odd, that file shows no features in Civil 3D or in MapGuide Studio 2009.
> What do you see when you open it in ArcMap?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
> Sent: Thursday, February 05, 2009 3:13 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Working with state plane data in Mapguide
> studio
> I am using Autodesk 2009. so its File->Convert DWG to Autodesk SDF
> option.
> Publish to mapguide option seems to create dwf instead of SDF. I need
> sdf.
> The coordinate system seems to be ok since it works well with shp in
> Arcmap.
> It is assigned and the right coordinate system is detected during the
> export.
> Here is a sample sdf. Thanks.
> Andy Morsell wrote:
>> It's probably a coordinate system issue.  Have you assigned the proper
>> coordinate system to the DWG project itself as well as specify it when
> you
>> export?  Which version of Autodesk Map are you using?  Are you using
> the
>> Map->Tools->Export to Autodesk MapGuide option or are you using the
>> Publish
>> to MapGuide option?
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
> clarkie342
>> Sent: Thursday, February 05, 2009 2:25 PM
>> Subject: [mapguide-users] Working with state plane data in Mapguide
> studio
>> I have some data in State Plane coordinate system (AL83-EF) in a
> AutoCAD
>> dwg.
>> I exported this data to SDF and opened in Mapguide Stuiod, data does
> not
>> show up in the layer preview.
>> Exporting it to shp and opening it in Arcmap works fine. Any ideas?
>> Thanks.
>> View this message in context:
> http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp
> 2277
>> 697p2277697.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/file/n2278016/boundary.zip boundary.zip
> 2277697p2278016.html
http://n2.nabble.com/file/n2278132/Facility.zip Facility.zip
View this message in context: http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp2277697p2278132.html
