[mapguide-users] Working with state plane data in Mapguide studio
clarkie342 f2000342 at gmail.com
Thu Feb 5 19:19:28 EST 2009
oops forgot the screenshot...here it is...
clarkie342 wrote:
> hmm weird! I have studio 2009.
> This is a snap shot of how is shows on my studio, this is the lower left
> corner of my screen...I cannot pan the map anymore, the features
> disappear. When I open the sdf in Civil 3D they show up fine.
> Note how the features have a slope in the screenshot, thats not how the
> features actually are.
> Mark Pendergraft wrote:
>> Okay, the Facility.sdf shows up in Civil 3d and in MapGuide Studio.  I
>> can select features and I can zoom in as well.
>> I've had trouble exporting features using Civil 3D in the past, it's
>> tricker than it looks.
>> What is distorted about the feature in MapGuide Studio?  What version of
>> MapGuide Studio do you have?
>> -Mark
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
>> Sent: Thursday, February 05, 2009 3:44 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] Working with state plane data in Mapguide
>> studio
>> I see the feature when I export it to shp and open it in arcmap.
>> attached in another layer from the DWG which shows up in Civil 3D but is
>> distorted in Mapguide studio. It also does not let me select features or
>> zoom properly.
>>> Odd, that file shows no features in Civil 3D or in MapGuide Studio
>> 2009.
>>> What do you see when you open it in ArcMap?
>> clarkie342
>>> Sent: Thursday, February 05, 2009 3:13 PM
>> Mapguide
>>> studio
>>> I am using Autodesk 2009. so its File->Convert DWG to Autodesk SDF
>>> option.
>>> Publish to mapguide option seems to create dwf instead of SDF. I need
>>> sdf.
>>> The coordinate system seems to be ok since it works well with shp in
>>> Arcmap.
>>> It is assigned and the right coordinate system is detected during the
>>> export.
>>> Here is a sample sdf. Thanks.
>>> Andy Morsell wrote:
>>>> It's probably a coordinate system issue.  Have you assigned the
>> proper
>>>> coordinate system to the DWG project itself as well as specify it
>> when
>>> you
>>>> export?  Which version of Autodesk Map are you using?  Are you using
>>> the
>>>> Map->Tools->Export to Autodesk MapGuide option or are you using the
>>>> Publish
>>>> to MapGuide option?
>>>> Andy Morsell, P.E.
>>>> Spatial Integrators, Inc.
>>>> www.SpatialGIS.com
>>> clarkie342
>>>> Sent: Thursday, February 05, 2009 2:25 PM
>>>> Subject: [mapguide-users] Working with state plane data in Mapguide
>>> studio
>>>> I have some data in State Plane coordinate system (AL83-EF) in a
>>> AutoCAD
>>>> dwg.
>>>> I exported this data to SDF and opened in Mapguide Stuiod, data does
>>> not
>>>> show up in the layer preview.
>>>> Exporting it to shp and opening it in Arcmap works fine. Any ideas?
>>>> Thanks.
>>>> View this message in context:
>> http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp
>>> 2277
>>>> 697p2277697.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://n2.nabble.com/file/n2278016/boundary.zip boundary.zip
>>> 2277697p2278016.html
>> http://n2.nabble.com/file/n2278132/Facility.zip Facility.zip
>> 2277697p2278132.html
http://n2.nabble.com/file/n2278254/studio.jpg
View this message in context: http://n2.nabble.com/Working-with-state-plane-data-in-Mapguide-studio-tp2277697p2278254.html
