[mapguide-users] how to use FDO api into MAPGUIDE applications
Rodolfo Moreno rmoreno at voxiva.com
Fri Feb 6 14:51:11 EST 2009
Hi Stefan, you can add and delete features using mapguide API, however you
can't create non add fields to the SHPs.
http://n2.nabble.com/Writing-data-to-a-shapefile-example--td1815692.html#a1815693
Ivan Milicevic wrote:
> Hello,
> Can you post some sample code for that?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
> Dalakov
> Sent: Friday, February 06, 2009 6:20 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] how to use FDO api into MAPGUIDE
> applications
> For sure you can modify SHP files with Mapguide API - I have application
> which adds and deletes features.
> I have not tried to create a SHP file, but I don't think it is
> impossible
> Stefan Dalakov
> Rodolfo Moreno wrote:
>> I have read that only SDFs can be created and altered with mapguide
> API,
>> which is why I need to use FDO api in my mapguide applications in
> order to
>> create and alter SHPs.
>> If anyone has code sample or documentation about it, I will be very
>> grateful.
>> Cheers,
>> Rodolfo Moreno
>> CivilEng
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/how-to-use-FDO-api-into-MAPGUIDE-applications-tp2284511p2286146.html
