[mapguide-users] Can I use MGSERVER2008 in both Appache and onsame machine?
Jason Birch Jason.Birch at nanaimo.ca
Fri Feb 6 14:58:17 EST 2009
I'm guessing that as long as Apache isn't running on port 80, you could
also perform a repair install on the web extensions to add the .Net
dlls, and then configure the mapguide virtual directories manually in
IIS.  There is info floating around there somewhere on how to do this.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Can I use MGSERVER2008 in both Appache and
onsame machine?
Yes. Just uninstall the web tier and reinstall it with .NET. Don't touch
the mgserver install.
Sent: Friday, February 06, 2009 8:40 AM
Subject: [mapguide-users] Can I use MGSERVER2008 in both Appache and on
same machine?
I am new and now working with MGSERVER on Apache Web Server with Php, I
would
like to study MapGuide API using ASP.NET, can I change MGSERVER to IIS
on
same machine?
