[mapguide-users] Can I use MGSERVER2008 in both Apache and IISon same machine?
nelyass.heglig at gnpoc.com nelyass.heglig at gnpoc.com
Fri Feb 6 23:24:39 EST 2009
Dear,
The MapGuide Server has nothing to do with which programming API you
use.
The web extensions is the one which determine your web server (iis,
apache) and programming api (.net, php or java).
So, uninstall the web extensions and reinstall it with .net environment.
There is another way with which you can let both php and .net work
together by creating two websites in the iis and configure each for its
programming api, but this is not supported.
I hope this will help you
Nadir Elyass
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of neazaem
Sent: Saturday, February 07, 2009 7:09 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Can I use MGSERVER2008 in both Apache and
IISon same machine?
Dave, Thank for your advice. But before I do this, can you give me
specific
part of MapGuide Component that I should uninstall. Is it MG Web Server
Extension?
thanks again.
Neaz
Dave Wilson wrote:
> Yes. Just uninstall the web tier and reinstall it with .NET. Don't
touch
> the mgserver install.
> Dave
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Friday, February 06, 2009 8:40 AM
> Subject: [mapguide-users] Can I use MGSERVER2008 in both Appache and
on
> same machine?
> I am new and now working with MGSERVER on Apache Web Server with Php,
I
> would
> like to study MapGuide API using ASP.NET, can I change MGSERVER to IIS
on
> same machine?
> thanks in advanced.
> regards
> neaz
http://n2.nabble.com/Can-I-use-MGSERVER2008-in-both-Appache-and-on-same-
machine--tp2284724p2284724.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
machine--tp2284724p2288005.html
