[mapguide-users] window open
Mark Pendergraft markp at Meadgilman.com
Mon Feb 9 01:28:13 EST 2009
What exactly are you trying to do?  If you have points in your map, you
can have a URL display in the map tip, when hovering over the point.
You can also pass parameters to the URL string using an expression.  All
of that can be done by editing the layer in MapGuide Studio.
If you can provide more information about what you would like your map
to do, I'm sure someone here could point you in the right direction.
-Mark P.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
Sent: Sunday, February 08, 2009 8:20 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] window open
  hi..all...
            to open a new window while clicking on the points displayed
on
the map where i've to write the coding...In which file i've to make
changes..&what change i've to make...plss help me...
thanks&regards
dyuti
View this message in context:
http://n2.nabble.com/window-open-tp2295629p2295629.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
