[mapguide-users] window open
DYUTI dyuti152006 at yahoo.com
Mon Feb 9 02:05:22 EST 2009
please refer this link then u'll get an idea about what i'm trying to do
http://www.edugrid.ac.in/webgis/2/keralainfo/
DYUTI wrote:
> thank u mark
>           my platform is mapguide maestro..my map having 3 layers.The
> third  layer having lot of points that points some places on the map,while
> clicking on these points a window should open.that contain info about the
> particular place..i'm newer in this..so plss help me....
> thanks
>  dyuti
> Mark Pendergraft wrote:
>> What exactly are you trying to do?  If you have points in your map, you
>> can have a URL display in the map tip, when hovering over the point.
>> You can also pass parameters to the URL string using an expression.  All
>> of that can be done by editing the layer in MapGuide Studio.
>> If you can provide more information about what you would like your map
>> to do, I'm sure someone here could point you in the right direction.
>> -Mark P.
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
>> Sent: Sunday, February 08, 2009 8:20 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] window open
>>   hi..all...
>>             to open a new window while clicking on the points displayed
>> on
>> the map where i've to write the coding...In which file i've to make
>> changes..&what change i've to make...plss help me...
>> thanks&regards
>> dyuti
>> View this message in context:
>> http://n2.nabble.com/window-open-tp2295629p2295629.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/window-open-tp2295629p2296057.html
