[mapguide-users] window open
DYUTI dyuti152006 at yahoo.com
Mon Feb 9 23:58:27 EST 2009
yes....i'm using fusion.would anyone plss explain how to write a widget?
thax &regards
dyuti
Mark Pendergraft wrote:
> Are you using Fusion?  I think the best choice would be to write a
> widget.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
> Sent: Sunday, February 08, 2009 11:05 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] window open
> please refer this link then u'll get an idea about what i'm trying to do
> http://www.edugrid.ac.in/webgis/2/keralainfo/
> DYUTI wrote:
>> thank u mark
>>           my platform is mapguide maestro..my map having 3 layers.The
>> third  layer having lot of points that points some places on the
> map,while
>> clicking on these points a window should open.that contain info about
> the
>> particular place..i'm newer in this..so plss help me....
>> thanks
>>  dyuti
>>> What exactly are you trying to do?  If you have points in your map,
> you
>>> can have a URL display in the map tip, when hovering over the point.
>>> You can also pass parameters to the URL string using an expression.
> All
>>> of that can be done by editing the layer in MapGuide Studio.
>>> If you can provide more information about what you would like your
> map
>>> to do, I'm sure someone here could point you in the right direction.
>>> -Mark P.
>>> Sent: Sunday, February 08, 2009 8:20 PM
>>> Subject: [mapguide-users] window open
>>>   hi..all...
>>>             to open a new window while clicking on the points
> displayed
>>> on
>>> the map where i've to write the coding...In which file i've to make
>>> changes..&what change i've to make...plss help me...
>>> thanks&regards
>>> dyuti
>>> View this message in context:
>>> http://n2.nabble.com/window-open-tp2295629p2295629.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/window-open-tp2295629p2296057.html
View this message in context: http://n2.nabble.com/window-open-tp2295629p2300983.html
