[mapguide-users] MapGuide Programming using C#, need help, please
staniz ustazin at yahoo.com
Tue Feb 10 05:30:17 EST 2009
I am using MGE Server and Studio 2008, windows XP and IIS 5.1. I downloaded
sample code from
http://download.autodesk.com/media/adn/DevTV_%20Introduction_to_MGE_Programming/SampleCode.zip
these code is recommended for MGE2007, but I think its also work for
MGE2008.
I followed all the instruction in video, and ran the default.aspx. Its
worked by but When I was trying to run the Query.aspx and execute the
DisplayQueryResult.aspx I got the following error:
Compiler Error Message : CS0266:
cannot implicitly convert type
`OSGeo.Mapguide.MgLayerBase` to
`OSGeo.Mapguide.MgLayer`. An explicit
conversion exist (are you missing a cast?)
Source code:
Line 58:  MgLayer layer =map.Getlayer().GetItem("Parcels");
.Net framwork Version:2.0.50727.42
please help to solve this problem...
thanks is advance.
staniz
View this message in context: http://n2.nabble.com/MapGuide-Programming-using-C-%2C-need-help%2C-please-tp2301814p2301814.html
