[mapguide-users] MapGuide Programming using C#, need help, please
djonio DJonio at miami-airport.com
Tue Feb 10 08:47:22 EST 2009
The compiler message is telling you in the most non-threating and kind way
... that you need a cast ... without looking at the api my guess is
something like ... MgLayer layer =
(MgLayer)map.Getlayer().GetItem("Parcels");
I assume MgLayer is derived from MgLayerBase and GetLayer returns
MgLayerBase ...
r,
dennis
staniz wrote:
> I am using MGE Server and Studio 2008, windows XP and IIS 5.1. I
> downloaded sample code from
> http://download.autodesk.com/media/adn/DevTV_%20Introduction_to_MGE_Programming/SampleCode.zip
> these code is recommended for MGE2007, but I think its also work for
> MGE2008.
> I followed all the instruction in video, and ran the default.aspx. Its
> worked by but When I was trying to run the Query.aspx and execute the
> DisplayQueryResult.aspx I got the following error:
> Compiler Error Message : CS0266:
> cannot implicitly convert type
> `OSGeo.Mapguide.MgLayerBase` to
> `OSGeo.Mapguide.MgLayer`. An explicit
> conversion exist (are you missing a cast?)
> Source code:
> Line 58:  MgLayer layer =map.Getlayer().GetItem("Parcels");
> .Net framwork Version:2.0.50727.42
> please help to solve this problem...
> thanks is advance.
> staniz
View this message in context: http://n2.nabble.com/MapGuide-Programming-using-C-%2C-need-help%2C-please-tp2301814p2302617.html
