[mapguide-users] window open
DYUTI dyuti152006 at yahoo.com
Thu Feb 12 01:59:27 EST 2009
thank u mark for replaying me.....
  can i  make some changes in these widgets or shall i write a new one to
open a window..one more question...shall i make any changes in php files
present in webserver/www/mapviwerphp...to open the window..
 any replies will be appreciated
thanks & regards
dyuti
Mark Pendergraft wrote:
> Look at the MapTip, Select, and CursorPosition widgets to get an idea of
> how to proceed.
> -Mark
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
> Sent: Tuesday, February 10, 2009 8:45 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] window open
> hi all.....
>           would anyone plss help me to write a widget for open a pop up
> window...i'm newer in mapguide&fusion.i don't know whether i'm in right
> direction...so plss help me ...
> thanks&regards
> dyuti
> DYUTI wrote:
>> yes....i'm using fusion.would anyone plss explain how to write a
> widget?
>> thax &regards
>> dyuti
>>> Are you using Fusion?  I think the best choice would be to write a
>>> widget.
>>> Sent: Sunday, February 08, 2009 11:05 PM
>>> please refer this link then u'll get an idea about what i'm trying to
> do
>>> http://www.edugrid.ac.in/webgis/2/keralainfo/
>>> DYUTI wrote:
>>>> thank u mark
>>>>           my platform is mapguide maestro..my map having 3
> layers.The
>>>> third  layer having lot of points that points some places on the
>>> map,while
>>>> clicking on these points a window should open.that contain info
> about
>>> the
>>>> particular place..i'm newer in this..so plss help me....
>>>> thanks
>>>>  dyuti
>>>>> What exactly are you trying to do?  If you have points in your map,
>>> you
>>>>> can have a URL display in the map tip, when hovering over the
> point.
>>>>> You can also pass parameters to the URL string using an expression.
>>> All
>>>>> of that can be done by editing the layer in MapGuide Studio.
>>>>> If you can provide more information about what you would like your
>>> map
>>>>> to do, I'm sure someone here could point you in the right
> direction.
>>>>> -Mark P.
>>>>> Sent: Sunday, February 08, 2009 8:20 PM
>>>>> Subject: [mapguide-users] window open
>>>>>   hi..all...
>>>>>             to open a new window while clicking on the points
>>> displayed
>>>>> on
>>>>> the map where i've to write the coding...In which file i've to make
>>>>> changes..&what change i've to make...plss help me...
>>>>> thanks&regards
>>>>> dyuti
>>>>> View this message in context:
>>>>> http://n2.nabble.com/window-open-tp2295629p2295629.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://n2.nabble.com/window-open-tp2295629p2296057.html
> http://n2.nabble.com/window-open-tp2295629p2306878.html
View this message in context: http://n2.nabble.com/window-open-tp2295629p2313466.html
