[mapguide-users] functiolaity difference of MapGuide OS and enterprise?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 12 02:59:27 EST 2009
MapGuide Enterprise and MapGuide Open Source, has used the same code
base so far.
Autodesk is the primary contributor of code to MapGuide Open Source, so
yes, the developers are the same.
As I understand it, MapGuide Enterprise releases are built from the Open
Source code.
You have to ask Autodesk what modifications, if any, they put into
MapGuide Enterprise.
The Enterprise version has a special Oracle provider that supports the
Oracle format used by
other Autodesk products, but not "raw" spatial data.
MapGuide Enterprise also features a Raster provider that is not open source.
Regards, Kenneth Skovhede, GEOGRAF A/S
Saka Royban skrev:
> I just found a difference about Oracle provider.
> So, Regarding perfomance and capabilities in server-side there sounds
> no difference. am i right?
> One more question. are developers of this 2 versions the same or even
> overlap? (maybe i should ask this in dev mailinglist)
> *From:* Martin Morrison <martin.morrison at edsi.com>
> *To:* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Sent:* Monday, February 9, 2009 7:30:33 PM
> *Subject:* RE: [mapguide-users] functiolaity difference of MapGuide OS
> and enterprise?
> A couple of the FDO providers are different.  You also get web support
> through the subscription center for Enterprise.
> Martin
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Saka Royban
> *Sent:* Monday, February 09, 2009 10:50 AM
> *To:* MapGuide
> *Subject:* [mapguide-users] functiolaity difference of MapGuide OS and
> enterprise?
> Hi all.
> I'm confused about differences of mapguide OS and enterprise version.
> there sounds no difference.
> but if really there is no difference (or i'm wrong about it) what's
> the benifit of MGOS to Autodesk?
> Thanks alot
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090212/12322105/attachment.html
