[mapguide-users] Connect to PostgreSQL database via DNS(Mapguide Studio 2009)
Rui Daniro ruidaniro at hotmail.co.uk
Thu Feb 12 13:07:16 EST 2009
Hi Kenneth,
Thanks a lot for  your help.
I tried with PostGIS Provider and it was worst than with ODBC, then I tried
with OGR and works fine, I am able to see and plot the points, but ...there
is always a but..after plotting the points on my map, when I try query one
of my dots returns an error.
Fusion Error:
WARNING: Exception occurred in AJAX callback.
SyntaxError: invalid label
xx)
Can you help me with this?
  _____
De: Kenneth Skovhede, GEOGRAF A/S (via Nabble)
[mailto:ml-user+64672-1645459268 at n2.nabble.com]
Enviada: 12 February 2009 07:37
Para: Rui Daniro
Assunto: Re: [mapguide-users] Connect to PostgreSQL database via
Have you tried both the PostGIS provider and the OGR provider?
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
Hi Kenneth,
Thank you very much for your time.
I followed your suggestion and I still unable to do it.
I tested the connection with a diferent piece of software and I was able to
do it. I tried to access and create a layer based on the data on my database
using Quantum GIS it works fine, only with Mapguide I am not able to do it.
I went to check  if there is any error in the log files and nothing.
Do you have any other suggestion ofr my problem?
Thanks again for you time.
Rui
Kenneth Skovhede, GEOGRAF A/S wrote:
They should work right away.
Do you get any errors in the log files?
The preview feature does not always work, because the data extent is
sometimes reported incorrectly.
Try to create a map, and set the coordinate systems and extent to fit
the layer, then add the layer.
You should now be able to preview the map.
To be certain, try adding a layer with data in the same region that you
know works.
Rui Daniro skrev:
Hi Kenneth,
Thanks for help, but I believe that is not my problem.  As I can see
Paulo problems is to connect to the database, but not my case, I am
able to connect and see the tabular data, the only thing I am not able
to do is plot my geometric data.
Anyway, I did a search on my systems and I could not found those dll's
so I decided copy and past them on the following folder
\MapGuideOpenSource2.0\Server\Bin\FDO . Do they need any customisation?
Rui
*De:* Kenneth Skovhede, GEOGRAF A/S (via Nabble)
[ml-user+64672-1645459268 at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2313537&i=0> ...
 <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2274344&i=0>
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2274344&i=0>]
*Enviada:* 05 February 2009 07:38
*Para:* Rui Daniro
*Assunto:* Re: [mapguide-users] Connect to PostgreSQL database via DNS
Hi Rui.
Please see if this explains your trouble:
http://n2.nabble.com/FDO-OGR-Provider-for-PostGreSQL-8.3-%2B-PostGis-td22700
66.html
Rui Daniro skrev:
Hi all,
I am using MapGuide Studio 2009 and have a database created using
PostgreSQL
which I connected to it using via DNS. I tested the connection and I
get a
message saying sucessful connected, then I defined the geometry
properties
and selected the appropiate coordinate system for the table which I
want to
map. On preview I can see the geometric properties adn data
properties, when
I select view data I am able to see my table data, but when I select
view
feature nothing happens. I can see the zoom/pan tool and the loading
animation, but nothing happens, I leave it for ages and nothing comes
up.
Can you help me with this? Can you highlight on this? Thank you in
advance.
best regards
Rui
mapguide-users mailing list
mapguide-users at ...
 <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2273611&i=0>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This email is a reply to your post @
http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Stud
io-2009%29-tp2268432p2273611.html
You can reply by email or by visting the link above.
View this message in context: RE: [mapguide-users] Connect to
PostgreSQL database via DNS (Mapguide Studio 2009)
<http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Stu
dio-2009%29-tp2268432p2274344.html>
Sent from the MapGuide Users mailing list archive
 <http://n2.nabble.com/MapGuide-Users-f1803227.html>
<http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2313537&i=1>
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2313537&i=2>
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2313537&i=3>
  _____
io-2009%29-tp2268432p2313537.html
View this message in context: http://n2.nabble.com/Connect-to-PostgreSQL-database-via-DNS-%28Mapguide-Studio-2009%29-tp2268432p2316503.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090212/ad3f6010/attachment.html
