[mapguide-users] How to Highlight Line Features
    padmini godavarthi
    godavarthi.padmini at gmail.com
    Fri Feb 13 07:05:51 EST 2009
I attached primary key as "OBJECTID" in my table
then i want to select the line feature based on this objectid.
My code is as follows
        Dim fetresource1 As MgResourceIdentifier = New
MgResourceIdentifier("Library://WaterNetwork/data/resource.FeatureSource")
        Dim nameQuery1 As MgFeatureQueryOptions = New
MgFeatureQueryOptions()
               nameQuery1.AddFeatureProperty(val1)
        nameQuery1.SetFilter("OBJECTID =20")
        Dim layer1 As MgLayer = map.GetLayers().GetItem("waterpipe")
             Dim value As String = ""
        Dim featureReader1 As MgFeatureReader =
featureService.SelectFeatures(fetresource1, layer1.GetFeatureClassName(),
nameQuery1)
        While featureReader1.ReadNext()
            Dim propertyType As Integer =
featureReader1.GetPropertyType("OBJECTID")
            value = GetFeaturePropertyValue(featureReader1, "OBJECTID")
        End While
        Dim selection As MgSelection = New MgSelection(map)
        selection.AddFeatures(layer1, featureReader1, 0)
        Dim selectXML As String = selection.ToXml()
        selection.Save(resourceService, "watermap")
        Page.ClientScript.RegisterStartupScript(Page.GetType(), "test",
"select('" & selectXML & "')", True)
        map.Save(resourceService)
        featureReader1.Close()
then after executing this code non of the line was selected.
Has any idea on it?
Thanks and Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> This is what I found from a quick search:
> http://www.techonthenet.com/oracle/primary_keys.php
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> is selection is done based on primary key of type integer?
>> Then in my table there is no primary key column.How can i achieve thin?
>> Thanks and Regards,
>> Padmini.
>>> It is not enough that it has unique values, there must be a primary key
>>> defined.
>>> Since you are using Oracle, the key must be defined on the Oracle table.
>>> IIRC, the primary key must also be of type integer.
>>>> Hi,
>>>> In my table STARTVALVE has unique valves .By using that "STARTVALVE"
>>>> property iam trying for selection .
>>>> Regards,
>>>> Padmini.
>>>>> You cannot use selection if the table does not have unique primary
>>>>> keys.
>>>>>> Hi,
>>>>>> In my table iam not having any primary key columns.
>>>>>> Thanks and Regards,
>>>>>> Padmini
>>>>>>> I think your data has broken primary keys (eg. empty strings as
>>>>>>> primary
>>>>>>> key).
>>>>>>>>   Hi,
>>>>>>>> iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>>>>> Now iam struck up with high lighting line features on the map.
>>>>>>>> my code is as follows:-
>>>>>>>>         Dim val1 As String = "STARTVALVE"
>>>>>>>>               nameQuery1.SetFilter("STARTVALVE ='124'")
>>>>>>>>         layer1.Selectable = True
>>>>>>>> nameQuery1)
>>>>>>>> "test",
>>>>>>>> function select(val) {
>>>>>>>>          var selectionXML = val;
>>>>>>>>           parent.parent.SetSelectionXML(selectionXML);
>>>>>>>>                  alert("Selected");
>>>>>>>>       parent.parent.refresh;
>>>>>>>> but the line  feature is not highlighting ?  but this code works
>>>>>>>> with
>>>>>>>> polygon feature.
>>>>>>>> i  found that in xml
>>>>>>>> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
>>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
>>>>>>>> id="1f6baf1e-0000-1000-8000-0016e692a356">  <Class
>>>>>>>> id="KingOra:IMCN~GIS_WATERPIPE_DETAILS~SHAPE">   <ID></ID>
>>>>>>>> <ID></ID>
>>>>>>>> </Class> </Layer></FeatureSet>
>>>>>>>> ID doesn't came.is there problem with ID?
>>>>>>>> Can u plz tell me the solution?
>>>>>>>> Thanks and Regards,
>>>>>>>> Padmini
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/How-to-Highlight-Line-Features-tp2307466p2320878.html
