[mapguide-users] Raster problem
Peter Filip reklamama at centrum.sk
Fri Feb 13 10:52:42 EST 2009
Hello,
I am having no success in loading my 2 tiff files.
I am using the Maestro tool. So i followed instruction in this guide
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/RasterFeatureSource
So i created a featuresource and i also set coordinate system overrides.
Then I wanted to create a layerdefinition. I picked out my created
featuresource and then a i got this error:
Failed to read schema from data source.
The operation gave the error message: Value cannot be null.
Parameter name: input
Byt anyway I could save the featuresource so I did.
I added this layer to a map but in the browser no raster show up. Just the
icon in the layer box.
This is the featuresource schema:
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.Gdal</Provider>
  <Parameter>
    <Name>DefaultRasterFileLocation</Name>
    <Value>D:\neroztriedene\raster\</Value>
  </Parameter>
  <SupplementalSpatialContextInfo>
    <Name>Default</Name>
<CoordinateSystem>PROJCS["S-JTSK_Krovak",GEOGCS["GCS_S_JTSK",DATUM["Jednotne_Trigonometricke_Site_Katastralni",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Krovak"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Pseudo_Standard_Parallel_1",78.5],PARAMETER["Scale_Factor",0.9999],PARAMETER["Azimuth",30.28813975277778],PARAMETER["Longitude_Of_Center",24.83333333333333],PARAMETER["Latitude_Of_Center",49.5],PARAMETER["X_Scale",1],PARAMETER["Y_Scale",1],PARAMETER["XY_Plane_Rotation",0],UNIT["Meter",1],AUTHORITY["EPSG","102065"]]</CoordinateSystem>
  </SupplementalSpatialContextInfo>
</FeatureSource>
And i also ran the interactive mode with CPL_DEBUG=ON
GDAL: GDALOpen(D:\neroztriedene\raster\/bero48.aux) succeeds as HFA.
GDAL: GDALOpen(D:\neroztriedene\raster\/bero48.tif) succeeds as GTiff.
GDAL: GDALOpen(D:\neroztriedene\raster\/bero49.aux) succeeds as HFA.
GDAL: GDALOpen(D:\neroztriedene\raster\/bero49.tif) succeeds as GTiff.
GDAL: GDALClose(D:\neroztriedene\raster\/bero49.aux)
GDAL: GDALClose(D:\neroztriedene\raster\/bero49.tif)
RfpDatasetCache::CloseAll(): Forcing closure of
aux even though there
are still references against it.
GDAL: GDALClose(D:\neroztriedene\raster\/bero48.tif)
GDAL: GDALClose(D:\neroztriedene\raster\/bero48.aux)
And my config is: Windows 2003, MGOS 2.0.2 .NET, Maestro 1.0.9.15910
I Hope somebody can help me.
Thanks!
View this message in context: http://n2.nabble.com/Raster-problem-tp2321922p2321922.html
