[mapguide-users] aspx code behind
ed57gmc-bus at yahoo.com ed57gmc-bus at yahoo.com
Fri Feb 13 11:03:33 EST 2009
Can you do that to regular html elements? Don't you have to use asp controls?
Ed Jobe
To: mapguide-users at lists.osgeo.org
Sent: Friday, February 13, 2009 4:31:03 AM
Subject: Re: [mapguide-users] aspx code behind
Include a runat="server" attribute in the html element you want to expose.
Then in the code-behind, either set its relevant properties or its
Attributes collection property.
- Jackie
staniz wrote:
> I am trying to make default.aspx with code behind.
> Can sameone helps to provide information of code behind with Mapguide API?
> default.aspx.cs
> using OSGeo.MapGuide;
> public partial class Default2 : System.Web.UI.Page
>    protected void Page_Load(object sender, EventArgs e)
>        MapGuideApi.MgInitializeWebTier(@"C:\Program
> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\webconfig.ini");
>        MgUserInformation userInfo = new MgUserInformation("Anonymous",
>        MgSite site = new MgSite();
>        site.Open(userInfo);
>        String sessionId = site.CreateSession();
>        String webLayout = "Library://DevTV/HelloWorld.WebLayout";
> default.aspx
> <html xmlns="http://www.w3.org/1999/xhtml" >
> <head>
>    <title>HelloWorld</title>
> </head>
> <frameset rows="0,*" border="0" framespacing="0">
>  <frame />
>  <frame id="ViewerFrame"
> src="/mapguide2008/mapviewernet/ajaxviewer.aspx?SESSION=sessionId&WEBLAYOUT=webLayout"/>
> </frameset>
> </html>
> How to sent value from code behind to aspx?
> please help..
> regards,
> Staniz
View this message in context: http://n2.nabble.com/aspx-code-behind-tp2319949p2320957.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090213/61a451f3/attachment.html
