[mapguide-users] FDO 3.4.0 Beta 1 - SQL 2008 - empty schema
miansi AndreiSinelnikov at SierraSystems.com
Fri Feb 13 12:22:32 EST 2009
I am trying to use FDO 3.4.0 Beta 1.
I have MGOS 2.0.2, I downloaded Windows SDK for FDO 3.4.0 Beta 1. and copied
everything from
directory into
C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO
I am using MapGuide Maestro v1.0.9.37733 and MapGuide Studio 2008
After replacing FDO I was able to create dataconnection to SQL 2008, but
then I tried to create layer using this data connection I noticed that
schema dropdown is empty:
No errors in C:\Program Files\MapGuideOpenSource2.0\Server\Logs
Do I have to update schemas or do something else to make it working?
Thank you
View this message in context: http://n2.nabble.com/FDO-3.4.0-Beta-1---SQL-2008---empty-schema-tp2322472p2322472.html
