[mapguide-users] FDO 3.4.0 Beta 1 - SQL 2008 - empty schema
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Feb 14 06:26:16 EST 2009
On this page:
http://localhost/mapguide/mapagent/index.html
Click "Feature", then "DescribeSchema".
Fill out the "ResourceID" field with the path of your FeatureSource,
then click "Submit".
If the result gives no schemas, you have some trouble with the provider.
If there are schemas in the xml, you have found a Maestro bug.
If so, please create a trac ticket, and attach the xml to the ticket.
Regards, Kenneth Skovhede, GEOGRAF A/S
miansi skrev:
> Hello,
> I am trying to use FDO 3.4.0 Beta 1.
> I have MGOS 2.0.2, I downloaded Windows SDK for FDO 3.4.0 Beta 1. and copied
> everything from
> fdosdk-win32-3.4.0_Beta1.tar\Bin
> directory into
> C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO
> I am using MapGuide Maestro v1.0.9.37733 and MapGuide Studio 2008
> After replacing FDO I was able to create dataconnection to SQL 2008, but
> then I tried to create layer using this data connection I noticed that
> schema dropdown is empty:
> http://n2.nabble.com/file/n2322472/FDO%2B3.4.png
> No errors in C:\Program Files\MapGuideOpenSource2.0\Server\Logs
> Do I have to update schemas or do something else to make it working?
> Thank you
